查看: 68180|回复: 159
[医学前沿] 侵袭性B细胞淋巴瘤首次缓解后美罗华维持
发表于 2016-2-28 16:55:46 | 显示全部楼层 |阅读模式 来自: 中国北京
Rituximab maintenance for patients with aggressive B-cell lymphoma in first remission: results of the randomized NHL13 trial.
Abstract
We investigated rituximab maintenance therapy in patients with diffuse large B-cell lymphoma (n=662) or follicular lymphoma grade 3b (n=21) in first complete remission. Patients were randomized to rituximab maintenance (n=338) or observation (n=345). At a median follow-up of 45 months, the event-free survival rate (the primary endpoint) at 3 years was 80.1% for rituximab maintenance versus 76.5% for observation. This difference was not statistically significant for the intent-to-treat population (likelihood ratio P=0.0670). The hazard ratio by treatment arm was 0.79 (95% confidence interval 0.57-1.08; P=0.1433). The secondary endpoint, progression-free survival was also not met for the whole statistical model (likelihood ratio P=0.3646). Of note, rituximab maintenance was superior to observation when treatment arms only were compared (hazard ratio: 0.62; 95% confidence interval 0.43-0.90; P=0.0120). Overall survival remained unchanged (92.0 versus 90.3%). In subgroup analysis male patients benefited from rituximab maintenance with regards to both event-free survival (84.1% versus 74.4%) (hazard ratio: 0.58; 95% confidence interval 0.36-0.94; P=0.0267) and progression-free survival (89.0% versus 77.6%) (hazard ratio: 0.45; 95% confidence interval 0.25-0.79; P=0.0058). Women had more grade 3/4 adverse events (P=0.0297) and infections (P=0.0341). Men with a low International Prognostic Index treated with rituximab had the best outcome. In summary, rituximab maintenance in first remission after R-CHOP-like treatment did not prolong event-free, progression-free or overall survival of patients with aggressive B-non-Hodgkin lymphoma. The significantly better outcome of men warrants further studies prior to the routine use of rituximab maintenance in men with low International Prognostic Index. This trial is registered under EUDRACT #2005-005187-90 and www.clinicaltrials.gov as #NCT00400478.
评分
参与人数 2家园豆 +6 收起 理由
秋枫 + 4 【秋枫】打赏了楼主4个家园豆。.
零零捌 + 2 【零零捌】打赏了楼主2个家园豆。.
查看全部评分
发表于 2017-8-16 10:41:28 | 显示全部楼层 来自: 中国黑龙江鹤岗
好像看不清呢!
 楼主| 发表于 2017-4-26 16:37:08 | 显示全部楼层 来自: 中国北京
大年三十 发表于 2017-4-26 16:24
哈哈,大神还记得我们病理有疑问呢!我们后来又重新切了白片去上肿李小秋重新做了,结论还是纵膈大B,大 ...
CD30阳性,应该可以比较肯定是原发纵隔大B。如果已经用满了八次美罗华,接下去没有必要再做两年的维持。
 楼主| 发表于 2018-2-3 14:37:07 | 显示全部楼层 来自: 中国北京
何少玲 发表于 2018-2-3 10:57
雨丝老师你好!我覆膜后淋巴瘤用rchop方案化疗8疗程现未达代谢性完全缓解现用rdhap二线化疗能帮我看看二线 ...
高级别B细胞淋巴瘤非特指型,在二线方案三个疗程后如果CR或接近CR就做自体干细胞移植。
发表于 2017-8-16 10:40:37 | 显示全部楼层 来自: 中国黑龙江鹤岗
楼主,帮我看看呗!看我总结的对吗?
 楼主| 发表于 2017-7-6 19:53:33 | 显示全部楼层 来自: 中国北京
做完该做的检查,然后按照医生的建议治疗。另外,做FISH检查的时候要做CCND1/IGH,还不能完全除外套细胞淋巴瘤。
慢淋/小淋巴细胞性淋巴瘤
发表于 2016-2-29 07:42:12 | 显示全部楼层 来自: 中国山西忻州
橙色雨丝 发表于 2016-2-28 17:13
这是一项来自欧洲的临床研究结果。共有662例弥漫大B和21例滤泡3B患者在首次缓解后被随机分为美罗华维持组或 ...
雨丝,老公是慢淋,还有大b细胞,需要用美罗华维持吗
 楼主| 发表于 2016-2-28 17:13:37 | 显示全部楼层 来自: 中国北京
这是一项来自欧洲的临床研究结果。共有662例弥漫大B和21例滤泡3B患者在首次缓解后被随机分为美罗华维持组或观察组。在中位随访期45个月内,三年无事件生存率分别为80.1%对76.5%,差别没有统计学意义。总生存率分别为92%对90.3%。男性患者似乎从美罗华维持中获益,维持组和观察组的无事件生存率分别为84.1%对74.4%,无进展生存率分别为89%对77.6%。具有较低IPI评分的男性从美罗华维持中获益最大。
总结:对于侵袭性B细胞淋巴瘤,经R-CHOP 样化疗获得首次缓解后,美罗华维持治疗不能延长无事件、无进展或者总生存期。在对具有较低IPI评分的男性患者常规性的进行美罗华维持治疗之前,仍需要进一步的临床试验来证实。
发表于 2016-2-28 21:16:36 | 显示全部楼层 来自: 中国天津
有个小问题 滤泡3B是等同于弥漫大B吗 所以能放在一起试验~?
如果不是的话 这个实验的结果 关于男性10%左右收益这个结论 是不是统计学意义不大啊?因为滤泡美罗华维持本身收益就大 这个10%受益的男性 包含大部分滤泡的话 那对弥漫大B的维持还是没有依据啊
安徽
发表于 2016-2-28 21:46:04 | 显示全部楼层 来自: 中国安徽池州
如果不是的话 这个实验的结果 关于男性10%左 ...
等同,都按弥漫大B方案化疗。
发表于 2016-2-28 22:06:03 | 显示全部楼层 来自: 中国天津
阿森 发表于 2016-2-28 21:46
等同,都按弥漫大B方案化疗。
哦 就是滤泡3B是已经有大B转化了的意思呗.. ..那我好好看看 ..10%不低了
 楼主| 发表于 2016-2-29 07:29:05 | 显示全部楼层 来自: 中国北京
滤泡3B在治疗上等同弥漫大B,不过你说的确实有道理,也许获益的正好都是滤泡3B的患者。因为没有看到全文,目前无法判断。
 楼主| 发表于 2016-2-29 09:57:59 | 显示全部楼层 来自: 中国北京
应该是不需要的。
发表于 2016-2-29 13:19:43 | 显示全部楼层 来自: 中国天津
橙色雨丝 发表于 2016-2-29 07:29
滤泡3B在治疗上等同弥漫大B,不过你说的确实有道理,也许获益的正好都是滤泡3B的患者。因为没有看到全文 ...
代入公式计算了一下 在不考虑滤泡的前提下 文中得出10%差异的男性对比人数(低分ipi男性应该是无法计算出的)应该70/70左右~一共140个人左右~这个属于什么容量的样本呢?是属于大样本吗 一般多少个人属于大样本啊~
 楼主| 发表于 2016-2-29 15:05:28 | 显示全部楼层 来自: 中国北京
linjiagenga1 发表于 2016-2-29 13:19
代入公式计算了一下 在不考虑滤泡的前提下 文中得出10%差异的男性对比人数(低分ipi男性应该是无法计算出 ...
几百人。
滤泡性淋巴瘤III级
医科大学
发表于 2016-3-15 14:09:12 | 显示全部楼层 来自: 中国辽宁大连
滤泡3A和3B的治疗方案不一样吗?
 楼主| 发表于 2016-3-15 14:20:24 | 显示全部楼层 来自: 中国北京
小何流水 发表于 2016-3-15 14:09
滤泡3A和3B的治疗方案不一样吗?
看具体情况。
发表于 2016-3-15 14:52:45 | 显示全部楼层 来自: 中国北京
是不是夸大了美罗华的作用,忽视了它的副作用。我打美罗华造成间质性肺病变,今天又来看中医。
发表于 2016-3-15 15:03:51 | 显示全部楼层 来自: 中国北京
雨丝是不是欧洲人和亚洲人有体质差异?
 楼主| 发表于 2016-3-15 16:13:36 | 显示全部楼层 来自: 中国北京
群星群星 发表于 2016-3-15 15:03
雨丝是不是欧洲人和亚洲人有体质差异?
主要是基因的差异。
边缘带B细胞淋巴瘤/malt淋巴瘤
尚未确认
发表于 2016-3-17 10:39:51 | 显示全部楼层 来自: 中国上海
雨丝,我爱人是眼部malt伴小区大细胞转化,应该如何治疗,pet全身没有病灶
 楼主| 发表于 2016-3-17 11:52:28 | 显示全部楼层 来自: 中国北京
化疗。
边缘带B细胞淋巴瘤/malt淋巴瘤
尚未确认
发表于 2016-3-17 12:56:52 | 显示全部楼层 来自: 中国上海
谢谢,这个预后如何,是参考弥漫大B的预后吗,医生现在建议4个化疗+2 放疗,或者6个疗程化疗,
发表于 2016-3-18 09:38:12 | 显示全部楼层 来自: 中国江苏南京
那50几岁男性弥漫大b完全缓解后再加两-4次美罗华维持也是可以的吧。主治是这么要求的。我们准备下个月去做了。
 楼主| 发表于 2016-3-18 10:12:42 | 显示全部楼层 来自: 中国北京
cabb 发表于 2016-3-18 09:38
那50几岁男性弥漫大b完全缓解后再加两-4次美罗华维持也是可以的吧。主治是这么要求的。我们准备下个月去做 ...
有些证据表明标准的375mg/m2美罗华剂量对老年男性可能是不足的,所以增加几次有可能获益。
