查看: 8376|回复: 6
慢淋转弥漫大B淋巴瘤有什么好的治疗建议
哈尔滨肿瘤医院
发表于 2015-4-29 20:08:29 | 显示全部楼层 |阅读模式 来自: 中国黑龙江七台河
我爱人原来是慢性淋巴细胞白血病,在化疗过程中转变为弥漫大B淋巴瘤,前三个方案都失败了,有的方案下去很多又反弹,有的方案效果不明显。瘤体长到12厘米多了,有时疼痛,他现在很悲观。我不知道哪个医院治疗经验更丰富,或者有什么好的药物吗?求助各位!万分感谢!
脾边缘带B细胞淋巴瘤
杜克医院
发表于 2015-4-30 07:30:52 | 显示全部楼层 来自: 美国
这是杰夫。沙曼大夫的一篇博文,关于慢淋转化的。因为我的英语跟中文是脱节的,翻译不好。你自己用翻译软件看吧。Jeff Sharman 是慢淋方面的专家。这里是他Blog的地址
http://www.cll-nhl.com
这是他的blog文章
Richter's Syndrome / Histologic Transformation
Patients with CLL or indolent NHL occasionally experience a significant clinical change in their disease where it becomes a lot more aggressive.  When this happens, the formerly "slow growing" cancer becomes a lot more nasty and in many cases the prognosis gets a lot worse.  In a number of publications, NHL, CLL) the average survival when this happens is about a year.  A number of those are older articles (retrospective / in pre-rituximab era) which may have been confounded by patient selection bias.  My own impression is that many patients do quite a bit better but that is at least what the literature reports.
In CLL/SLL this is called "Richter's Transformation (RT)" while in the indolent NHL's this is called, "Histologic Transformation (HT)."  Sometimes docs jumble these terms and call it "Richter's Syndrome" or "transformation" regardless of which disease it started out as.  There is a different discussion about what we call Grade 3 follicular lymphoma.  Sometimes these can be confused by the patient.  I will save the discussion of Grade 3 until an upcoming post.  In follicular lymphoma HT occurs at a rate of about 3%/year.  While that is a pretty small number, it is cumulative so by 10 years it may be as high as 30%. In CLL the rate appears to be a fair bit lower so that the cumulative risk is only about 10-15%.
The best clue that a patient has undergone RT/HT is when the disease acquires a bad attitude.  Instead of just involving blood and lymph nodes, you see it in new places like liver, lung, intestine, bone nodules, sometimes even brain.  Patients might experience increasing fevers, night sweats, weight loss.  Laboratory changes are notable for a significant rise in a blood marker known as LDH (we are not talking about subtle changes, but 2-4x higher).  If you get a PET scan (which measures metabolic activity of tissues), you might get one spot which is disproportionately "hot."
Traditional risk factors for developing this in CLL include an increasing number of prior therapies, CLL diagnosis at a younger age (longer exposure to risk), and more advanced disease.  A number of newer studies show that pre-existing NOTCH mutations, "stereotyped B-cell receptors (a topic for a future post)," 17p deletions etc. also increase the risk.  In indolent NHL, risk factors include the diagnosis of grade III follicular NHL, advanced disease, high flipi scores, and several lab variables (LDH, B2 microglobulin).
Under the microscope, the new disease most commonly resembles the "intermediate grade" Diffuse Large B Cell Lymphoma.  Less commonly it can look like Hodgkin's Disease, and extremely rarely it may look like Burkitt's or Lymphoblastic Lymphoma.  In any case, it goes from "indolent" to aggressive, or even the highly aggressive.
Because it is so easy to get samples of cancer cells from patients with CLL (blood draw), we know a lot more about transformation in CLL than we do in low grade lymphoma.  It is probably worth while therefore writing about what occurs in CLL and then highlighting the differences that we know about in NHL.
In CLL there are two main and one uncommon way of experiencing RT.  The most common way (80%)  is for the dominant CLL clone to acquire more and more genomic mutations over time.  Typically these involve several important genes including p53, Myc, and NOTCH.  The second most common way (20%) is for a patient with CLL to "spontaneously" develop an entirely new diffuse large B cell lymphoma that is clonally unrelated to the original CLL. You might think no patient should ever have such bad luck, but in a prior post about 13q, I detailed how some genomic deletions can predisopose to lymphoid malignancies.  Some patients who develop CLL may in fact be predisoposed to the spontaneous development of DLBCL.
The difference is significant.  In the first case, you have a highly resistant clone - often with a p53 mutation - giving rise to an aggressive lymphoid malignancy.  When p53 mutations are present, chemotherapy often does not work well.  Just like every other cancer we have ever studied, p53 is a BAD THING to have mutated in DLBCL.  Conversely, when DLBCL develops spontaneously, it is often a curable cancer.  This plays out with regard to prognosis of the transformation.  In the former, survival averages about a year, whereas in the latter a good number of patients are cured.  Once again, I would point out that it is frustrating that we have no way to tell which one a patient has with testing that we would consider readily available.  In indolent lymphoma, it seems far more likely that the new DLBCL is clonally related and p53 mutations are as high as 80%!
Treatment often consists of R-CHOP chemotherapy regardless of which sort of RT you have.  While this is typically a well tolerated treatment, it is harder on the patient if they have already been exposed to a bunch of chemotherapy previously.  You only get to beat up the bone marrow so many times (chemo) before it starts telling you it can't accept more flogging.  It is not uncommon to run into dose delays, or reduced dosing, etc.  Add this to more resistant disease and you can probably figure why it is less effective.  Furthermore, a lot of patients with follicular lymphoma have been previously treated with the "H" in R-CHOP and you can only give so many doses of that drug before the heart starts to complain.  Since treatment is less effective, some patients will be treated with an "auto" stem cell transplant but a lot depends on how robust the patient is at that point and how well they responded to therapy.
In the future, I think this may be one situation where the "engineered T cells" could become an important therapy.  NOTCH antibodies have recently entered clinical trials and might be appealing.  We have used brentuximab vedotin in one clinical trial and been pleased with the results for some of our patients.  Hopefully these newer approaches will give a more favorable outlook to patients with RS/HT sometime soon.
Here is a video I did with Brian Koffman describing it all:  Richters Transformation
组织活动:9
1147
资深病友
发表于 2015-4-29 20:11:17 | 显示全部楼层 来自: 中国北京
已用过哪些方案,病理报告呢
发表于 2015-4-29 20:48:58 | 显示全部楼层 来自: 中国北京
CLL出现Richter转化后非常难治,一般建议参加临床试验,国外有患者参加美罗华加抗CD22抗体Pinatuznmah vedotin的临床试验后获得不错的缓解,可惜这个试验还没有在中国开展。不知道北肿的CAR-T试验是否收治这种转化的病人,可以咨询一下。
发表于 2015-4-29 21:49:54 | 显示全部楼层 来自: 中国四川宜宾
去北京找专家订方案吧,别放弃多开导他让他到群里来大家一起战胜淋巴瘤。
哈尔滨肿瘤医院
 楼主| 发表于 2015-4-30 05:59:01 | 显示全部楼层 来自: 中国黑龙江七台河
非常感谢你们的建议和鼓励!
四川大学华西医院
一生平安康复0-1年
发表于 2015-4-30 10:09:47 | 显示全部楼层 来自: 中国四川
橙色雨丝的简明厄要
